My dryer was running the power went off and came right back on. I tuurn dryer back on and it is not heating any more. can you help?
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
