My Dryer Sweaks until the load gets hot what part is bad is it a bearing on the drum assembly or a idier wheel with a bad bearing?
The rear bearing kit is most likely your problem. The part # is 5303281153. It will come with a tube of greese in the kit. Fill up the plastic cup, that the drum fits in. The manufacturer never puts enough. Tom http://www.applianceeducator.com/parts.htm
