The last couple of loads I’ve done, the clothes are pretty soggy after the spin cycle. I just pulled the drain hose out of the drain and put it in a bucket and its draining fine. Ran it through a spin cycle again and it spins great. My girlfriend said this happened before and the appliance guy said he had to clean a drain filter or strainer… any ideas??? Thanks
The pump and pump filter on these models gets clogged pretty easily. I would say clean that out and see if that does not improve things. Something is probably clogged somewhere.
