the clothes in the washer do not spin dry after the spin dry cycle finishes and I am having to repeat this cycle several times to have dry enough clothes to put in the dryer- what should I check as far as hoses are concerned etc?? could there be something that is blocked?? please advise. The washer was purchased in July 2005.
— Begin quote from sally57;410777
Sally,
As far as hoses, you’ll need to check the drain hose for bends and kinks,
Does the spin basket ever get to a high spin speed ?
Otherwise , you’ll need to remove the front panel, and check the drive belt and clutch assembly, and drain pump and motor inverter.
[part]AP2044592[/part]
[part]AP3205861[/part]
[part]AP3160348[/part]
[part]AP3191798[/part]
Could get pretty involved, but doable.
Good Luck,
