To start with it would not spin. Code was E47. I replaced the control board. Now it is E5E. I went ahead and replaced the Lock switch Still E5E. I checked the delay, the soap door, and the water pump for cloges and make sure it works. all those seem good. I even put the old control board on just for kicks and now it is E5E not E47. If your going to tell me to check the wiring - how? It did say to replace the speed control but I don’t know where that is. Any thoughts?
According to the [AP3891780](http://manuals.frigidaire.com/prodinfo_pdf/Webster/1345417.pdf"]tech sheets[/URL] and because you already replaced the door lock and the main control board, the next step is to replace the speed control board (#4 on the diagram)
- The part number for the motor (speed) control board is [URL="http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=3891780&&model_id=5153228&diagram_id=1251781)
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=1251781&&model_id=5153228
