Will not heat.
replaced both fuses and heating element
Dryer work until moved to to location and changed the vent from the side to the back.
If I am understanding you right you moved to a new house and dryer doesn’t work? if this is true I would check the line voltage to the dryer You may have a problem with the house electrical and not the dryer
