Hello - my wife and I just moved into a newer home about a week ago. Today we decided to bake some muffins in the RBS305PRS00 (note change from post info above) Electric Wall Oven, a bit older than 1 year. The oven was set for 350F and the front panel said that it was preheating - countdown timer showed 13 minutes, the fan came on. After 13 minutes the oven was stone cold, no errors - the front panel read "350F." Similarly there were no results on attempts to broil and self clean. I flipped the breaker back and forth and had the same result - but power is definitely getting to the oven since the front panel is on. Any thoughts? Thanks in advance. B
Ben,
Red/white wire means a red wire with white strip on it. If there is no such wire then you have to remove the oven from the cabinet to test the thermal fuse. I can not see another way how to do it.
I agree - this morning I pulled the oven and found the thermal fuse. The fuse showed an open circuit at room temperature, so it is bad. I have ordered the part from appliancepartspro - to arrive in the near future. Looks like there was a service flash on these whirlpool models, it seems that the location of the fuse - in line with the exhaust fan has caused it to prematurely blow on many ovens (especially when performing a self-clean). Some have recommended moving the fuse location over 6 inches to avoid this problem - to more accurately test the ambient air. However, I dont have any 150C rated wire to use to allow enough length for this change. For now I will just replace the fuse and run the autoclean only extremely rarely.
Thanks for your help Gene.
Ben
You can try to find a replacement relay by using the numbers from the old relay. Otherwise you have to replace the control board.
- The control board AP3750535
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160587
