I checked some of the other threads and found some similar problems but figured I’d better start my own.
Whirlpool elec wall-oven (RBS245PDB12) will not heat.
*Both the bake and broil elements will not heat at all.
*Front display looks fine. NO ERROR MESSAGES
*Ohm checked both elements and were OK
*Ohm checked temp sensor and it was at 1100 or so
Thanks Gene, I actually replaced the thermal fuse today. Unfortunately I think there is more to it.
Now the oven heats but not above 325 or so. The display constantly shows ‘HEAT’ meaning the oven is still trying to reach the selected temp (375 or whatever).
As I said above I tested the temp sensor earlier and it was OK for continutity.
