Whirlpool oven does not bake nor broil
Ovens panel looks like it’s working but the oven just doesn’t heat up at all. Tried resetting the breakers and it still does not work. Any help is appreciated. Thanks!
Here is the parts breakdown
[https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301758.pdf](http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=rbs305prb00"]Model RBS305PRB00[/URL]
Here is the tech sheet
[URL="https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301758.pdf)
Note the Thermal Fuse
