Error Code Whirlpool DBL Oven
I was having problems with losing the display on the clock so after reading a few posts on this forum with the same problem, I purchased a new control board. Got it in yesterday, the clock works but when I turn on the oven I get a E1 F2 code. I disconnected the power, rechecked the connections, cleaned the ribbon for the control panel, then turned it back on. The oven came on very briefly, but then the same error codes came back. ANy help?
— Begin quote from ccervantes;251797
Did you notice any damage to the key pad ribbon tracers ?
Did the ribbon fit tight into the control board connector ?
Are you sure you did not twist the ribbon,and connect it upside down ?l
The F2 E1 code indicates, the control is not seeing the ribbon attached to the control board.
It appears you may need a control panel assembly, once you’ve cleaned and checked everything again.
[part]AP3131916[/part]
Thanks Joe, I am going to try and reconnect the ribbon a few more times and see what happens.
— Begin quote from ccervantes;251805
Ok,
I can understand that.
It would not be the first time that the control and touchpad assembly had to be replaced, to make a machine operate.
Good luck,
:wink:
Joe, I ended up getting a new control panel, and it worked! Very happy, thanks for all the help. I did notice crack in the ribbon which may have been the culprit.
— Begin quote from ccervantes;255842
Great,
Glad to hear you got the oven working.
Yes, the crack was the problem, in some cases a deep crease in the ribbon causes a failure on new parts as well(mis handling or packaging).
:slight_smile: :slight_smile: :slight_smile: :cool:
