Hi, this weekend my refrigerator staring making a loud noise. A bit later, the food in the freezer started to defrost. To make a long story short, I took the deck out of the freezer and saw that the evaporator motor was spinning okay, but the fan wasn’t. It had gotten loose from the shaft somehow and was just sitting there, not spinning so no air was circulating.
My question is: what do I need to get the fan back on the shaft so it won’t come loose again? I made a temporary fix by using a small hose clamp but I’m afraid that this is too much weight for the motor and it will burn up. Everything is working again but I don’t think the small hose clamp is a permanent fix. What parts do I need? I won’t have to buy new motor fan combo will I?
Thanks in advance for all your help!!
-Derek
