everything seems to be working
well, the ref and freezer are not cooling. the compressor and fans are all working , it is freezing on the line going into the coil, but the rest of the coil doesn’t seem to be getting cold enough to cool the freezer of fridge… the defrost seems to be working when hitting the the light button 5 times , it clears the line off fairly fast but just wont cool… any suggestions ?
You have sealed system problems, gauges and amprobe would confirm.
Thank you. I figured it was something like that. The way its freezing in the single line seems like its low on Freon. Or leaking off somewhere. Service tech will be here tomorrow.
I would not spend too much money on this, refrigerant leaks usually ruin compressors.
