Extended drying time
Dryer is not drying properly. Takes about 3 cycles to fully dry clothes. There is some heat however. So far I have checked the heating element itself for any breaks and with meter. Checks out fine. I then scoured online for help and concluded the most common culprits are the thermal cutoff switch, high limit thermostat but these also checked out fine as well. Then I suspected I had found the problem in the internal bias thermostat because I read somewhere that 2 of the leads on it should read 0 ohms and it did and the other set should read 7 ohms and it didn’t. Excited with the anticipation of a fix I ordered the part from AP PROS only to be disappointed as this didn’t fix the problem. I at my wits end with this but it’s not in me to simply give up, after all it’s only 6 yrs. old and a higher end unit with the bells & whistles. Any advice on this would be greatly appreciated.
Signed,
Not ready for the curb
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GEQ9800PW1
The most common cause for your symptoms is a partially plugged vent system.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer’s vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Did you check to see if it was grounded?
Both heater connections should measure infinite ohms to the case/frame when disconnected from the wiring.
Depending how it grounds it can cause low heat and the thermostat cannot regulate it.
The thermostat’s internal heater should be approximately 5,000 ohms.
In any case it being open will not cause your problem.
It would give you a symptom of no low heat.
FYI: This heater is turned on for lower temperature settings. It adds heat to the thermostat causing it to turn off more often. This results in a lower dryer heat output.
