F-2 Error Code on Jenn-Air Wall mount Oven
:eek: :confused: :mad: Got F-2 Error code(Oven temperature too Hot). There is a short that is causing the top broiler to stay on even when oven is off. I have to shut off the double-pole breaker off in the circuit breaker panel in order to get the oven to shut off. Already replaced Relay board and oven-temp sensor, and checked the wiring harnesses, but problem keeps coming back. Noticed that a ground connection is grounded to the oven wall near were the bottom burner plugs in. Wire and ring terminal are corroded. Could this be causing the problem?
