Oven showing code F2
Performed an oven self clean and afterwards the fan would not shut off and the display shows a code F2. What is most likely trouble? Thanks
"F2" error code means a runaway temperature. Measure the oven sensor (12 on the [B]AP4095668 resistance which should be about 1100 Ohms at the room temperature. If there is nothing wrong then replace the relay board (#11 on the diagram).
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=672658&&model_id=46579
