F06 E02 - F01 E02 and F03 E02 error codes
Washing a single pair of jeans when ( I beleive ) during the spin cycle we heard a noise from the laundry room. Sounded like clicking noises. Machine stopped and door was locked. Error code F06 E02 was displayed . After un plugging and re plugging in unit several times, the machine appeared to boot up normally however ; when trying to start a cycle, error code F01 e02 was then displayed . Most recently I have seen the error code F03 E 02 as well. The front user panel ( with the dial ) appears to be working. Beeps when you turn the dial for different cycles, Power button appears to work Etc. took off the back panel and attempted to check to see if I had 120v at the MCU. I have no voltage on pink wires. The error codes point me in different directions. Drum spins freely as well. I am thinking it’s the control board, can anyone else advise on what the most likely cause is? Not sure if it matters but the machine had not finished its cycle either. There was water in the drum which may be the cause of the door being locked.
