f1 error double electric oven tried stuff already
i have a haunting f1 code i have replaced the control board and both relay boards…
oven seems to work fine except after a few minutes of not being used it starts beeping with f-1 code
next thing i’d like to check is the temp sensor? not sure if i got the right part i grabbed the thermal switch on top of the oven but im not sure if that is the part i need to look at?
i’m thinking the oven doesn’t register room temp? as i get no error codes if i am using the oven? not sure as i swapped out the expensive crap already and still getting same code !@#$%^
someone please help point me in a direction of hope…
o and the thermal switch offers 0 resistance at room temp and the reset switch seems to work ok.
temp probes give me 1092 top oven and 1048 bottom oven so i guess it isn’t that!@#$%
Hi.
I’m afraid the control panel/touch pad for your oven is no longer available.
Control panel 318030135
Thank you.
Simon.
i already changed the control board…
Hi.
I was referring to the control panel (touchpad), not the control board.
Thank you,
Simon.
that is what i changed and i also had the relay boards checked out
Hi.
If you don’t mind, please, give me the part numbers of the controls that you have replaced.
Thank you,
Simon.
