Fault Code F1 - ERR
Appliance Parts Pros, After doing extensive research on posts it was recommended I replace The Surface Unit Control board (AP4499660) to fix Fault Error Code F1. I had carefully replaced this board without any luck. I had checked the board and it’s connections twice over, also mapping the wiring diagram with its connections etc… again no luck.
Can you smart folks suggest any other causes of this problem? Did I replace the correct part?
Please let me know ASAP as 1. Christmas is in 2 days and my wife wants to chew my head off :wink:
2. The part was $185 with shipping, and I’d like to double check my options before I send it back…
Thanks, Thomas:eek:
What is all wrong with it?
Does it display F1 right away, all the time?
— Begin quote from ApplianceJunk;634390
Correct, I plug the power back in and within a few seconds as I try to press any function keys, Timer, Bake, Oven, Clean clock, etc…the error code comes on with beeping sound…The only functions are the ceramic cook tops, thats it.
