Help"… I was having an F11 code at the start of the wash it would just start adding water and right after I would get F11.tried to run diag.test and would go right to F11.Did some reading and It pointed out to a bad CCU so I ordered a new CCU still having the same issues. Now I wounder if it’s theMCU that’s bad.But I see that the MCU is on factory back order.will send back CCU thanks to the return system that appliance parts have…any input would be great,thanks…
Hello, thank you for asking your question here.
The F11 error code indicates an issue with the ccu/mcu or the wire harness between the two.
99% of the time the MCU is the culprit. Since you already replaced the CCU that rules that out and it has to be the MCU. Order the MCU and replace it to solve this error code.
