We have a Tappan oven beeping and showing F5 Code after a power outage. The only time is does not do this is when the oven is on. Do we need to replace the EOC? Is this the same as the oven timer control? Is this a hard repair to do? Part is pricey, but not as much as new stove. Thanks!
Wow, that seems like a lot of money for replacing a control board. The part you found on this site is indeed the control board you are looking for and yes you can replace it yourself.
Just heard back from the repair co. it needs both a module control assembly and a keypad assembly. I see 5 different ones listed under parts for my model. I guess I have to take the old one out and see if there is a part number on it to figure out which one I need, 600 still seems high.
