Dispenser not dispensing.Suspect a clogged line or a dispenser valve problem. I could not find any kind dispenser control for this model on this website. Does this model have one and if not, what controls the flow of the softener into the tub?
There is no line or valve that control the fabric softener dispenser.
Pull it out of the agitator and soak it in many changes of hot water for about three days. These things get all gunky with that stuff.
After reading your reply I pulled the softener can out of the agitator and mucked it out like you suggested. While I did that, the XYL mucked out the little holes in the agitator where the softener exits during the spin cycle. They were pretty much clogged up.
Works like a charm now. Thanks!
