final spin not spinning fast
In final spin mode washer won’t spin water does drain and everything else works but it will not spin fast.
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
— Begin quote from martiniman;117901
WATER SPINS OUT. EVERYTHING WORKS OK, JUST HAS THE WHINE DURING SPIN.
This morning my dryer won’t heat, The element shows continuity, in the heat box above the element is a thermal cut off, it tests open. This is whirlpool part #3977393. I believe this should measure to have continuity, am I on the right trail?
Dennis
Here is the parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LEQ9558KQ0
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208299799.pdf
[COLOR="Blue"]
I believe this should measure to have continuity, am I on the right trail?[/COLOR]
Yes it should be 0 ohms.
You have to find out what caused it to go.
Note: that sometimes they do just blow on their own but changing it without checking other things is a gamble. I believe richappy (another regular poster on this forum) has done a study on thermostats and found a wide variation of actual trip point and what is specified.
Check the heating coil.
Check it with a meter, should be around 10 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and the thermostats cannot regulate it.
If the above is OK then you will also have to replace the hi-limit as it should have regulated the temperature so the fuse did not blow.
You still have to find out why it blew.
Check that the belt is OK.
Check the seals (drum etc) in the unit. The air is pulled over the heating coils, through the drum and pushed out the exhaust. So any large seal leak will pull in room air and the cycling thermostat on the blower will run the unit hot.
Check that the lint filter is not coated with fabric softener residue which greatly reduces air flow.
Check/clean your vent system.
Check/clean the blower wheel.
If all OK you may want to replace the cycling thermostat as it’s contacts may not be opening (welded shut).
