Fluctuating temp
Have a Whirlpool Gold Super capacity 465 accubake.
The temp jumps around - high and low when baking. As much as 50 degrees up or down. The digital board read 375 and actual over temp will be off. Help!! This makes it very hard to bake anything.
Thanks Ron
Hi Ron,
Here are the break down diagrams for the Whirlpool range http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=107197&&model_id=262902
— Begin quote from Gene;11636
Hi Ron,
Here are the break down diagrams for the Whirlpool range [URL="http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=107197&&model_id=262902)
Good luck.
Thanks Gene, just to clarify, if the sensor reading is 1079 ohms should I only order the control board?
Ron
