Freezer freezing ok refrigerator not cooling
I have had this frig 5 yrs. All of a sudden I realize the refrigerator is running constantly and I notice the freezer seems to be working properly and it’s making ice. But the refrigerator side is not cooling properly. I vacuumed the front and rear coils under refrigerator.( they were not excessively dirty ) Any quick fix to my problem?
Pull the back freezer panel. If the freezer coils are entirely frozen up, check the little round defrost thermostat clipped on the evaporator while still cold it should be shorted. If ok, check the defrost heater,if ok. you probably have a bad defrost timer. Defrost the coils with a hair dryer. You can click on yor model # above for take apart info.
Need model # and make.
