freezer gets to warm
When the the freezer gets through its defrost phase and the the coils are free of ice, the freezer warms up to 30’, I have to unplug the refrigerator and plug it back in to get the fan going again to start cooling down the freezer eventually the freezer gets to the proper temperature; but when it goes through the defrost cycle again the same thing happens. I have had problems with the fresh food freezing and high temps in refer part as well. Could it be the defrost thermostat and or temperature sensor ? Thanks Mike
Mike, the key thingt here that is the problem, is not the defrost cycle, but the fan in the freezer. GE is notorious for a bad circuit going to the evaporator fasn motor. The fix is a new Motherboard, located on the back side of the refrigerator, behind a small metal panel. Tom http://www.applianceeducator.com/parts.htm
— Begin quote from kayakcrzy;346451
Mike, the key thingt here that is the problem, is not the defrost cycle, but the fan in the freezer. GE is notorious for a bad circuit going to the evaporator fasn motor. The fix is a new Motherboard, located on the back side of the refrigerator, behind a small metal panel. Tom Appliance Educator, Appliance Parts, Washer and Dryer Parts, Refridgerator and Freezer Parts, Stove and Oven Parts
Everything ran fine last night, this morning the temperatures are all where they are suppose to be and the evaporator fan is running any thoughts? Thank you, Mike
Motherboard!!! It will happen again!!! I am a repairman of 30 years. I do it everyday!!! If the fam motor stops running in the freezer, alot of times, the water in the door, won’t work either. There are my thoughts. Good Luck!!! Tom http://www.applianceeducator.com
— Begin quote from kayakcrzy;346617
Motherboard!!! It will happen again!!! I am a repairman of 30 years. I do it everyday!!! If the fam motor stops running in the freezer, alot of times, the water in the door, won’t work either. There are my thoughts. Good Luck!!! Tom ApplianceEducator.com
I appreciate the help, I have also had the water stop working in the door so your advice is very much appreciated and will be ordering a new motherboard. Is the motherboard pretty straight forward to install…
Thank you, Mike
