[CENTER]i just plugged in freezer after it has been sitting the compressor seems to be running fine but its not cooling off inside no air blkowing inside or anythning any segustions
[/CENTER]
Hi.
Check if the evaporator fan is running and if the evaporator coils are covered with frost?
Thank you. Post the results.
Simon.
ok i checked the fan and coils the fan wasent spinning till i spun it now seems to be working fine but the coils arent getting cool at all
Hi.
If the compressor is definitely running and it’s worm to a touch but the evaporator not frosting over - there is the sealed system problem: no freon, restriction, compressor.
Any of this will be $$. Call the service co.
Thank you.
Simon.
ok does it matter that it was on its back for afew hours we let it stand up a day before pluggin g it in but could this have any thing to do with it and how long does it have to be running to start getting cold thank you for your help
Hi.
Within 12hrs it should be subzero temperature. Being on the back
allows the oil from the compressor to escape into system and when you turned it on - the oil blocks the capillary tube.
That called a restriction.
This problem is not going to go away by itself.
Simon.
— Begin quote from Simon / APP Team;745132
Hi.
Simon.
it was out of freon all the way no pressure in the line its on its way to scrap yard now thank you for your help
You are very welcome.
Simon.
