can not get washer to drain ,spins but wont drain blew thru drain line and bubbled in tub help
Hi.
Remove the front panel to get an access to the drain pump and hoses.
Check if the drain pump gets 120VAC when washer is set to drain. If it does and it’s not working - replace the pump
Before replacing it make sure that the tub to pump hose is not blocked.
If the pump is not getting proper voltage check the wire harness and connectors.
If everything checks out OK - replace the timer
Here are the breakdown diagrams and http://www.appliancepartspros.com/control-panel-parts-for-frigidaire-fex831fs4.html
Post the results.
Simon.
Hi.
Before replacing it make sure that the tub to pump hose and the drain hose are not blocked.
Post the results.
Simon.
the pump appears to be getting the correct voltage however does not work .when i had the pump out i hooked it direct to an out let and it worked fine,the machine is not spinning as well
Did you replace the pump and the new one is doing the same thing?
Did you check the voltage between the pump contacts and what was it?
Simon.
— Begin quote from Simon / APP Team;802519
Simon.
just found some broken wires going from the lid switch,i guess from an uneven load.i will spice them and let you know the outcome
ha do i feel like a dumbass that was it.thanks for your help
I’m glad you where able to fix the problem. The proper voltage check helps with diagnostics.
Simon.
