My Washer Wont Drain
My Fronyt Load Machine Wont Drain Any Water Out I Can Syphone It Out Through The Hose But Wot Drain On Any Cycle It Will Spin Just Wont Drain I Am Thinking Its The Pump The Drain Hose Is Connected To Ut I Am Not Sure How To Test This Theory Or What The Proper Name Would Be To Order The Part Any Help Would Be Appericiated
Remove the tub drain hose from the drain pump and clean it out.It has a filter in there that may be bad, try not to remove the boot from the tub, clamp hard to get back on. If ok, check the pump impeller, sometimes they break. If ok, replace the pump AP4359998
— Begin quote from richappy;108238
would ya believe i took the pump off and tested it and it wouldnt work so i just happened t5o wangt to see how it was made so i took it apart and a dam nail fell out now it works like a charm thanks for your help!!!
So it started by stopping at some point in the cycle. I could move to Spin to empty the water if I unplugged it for 10 mins or more. Then I could restart and it would agitate for 30-45 seconds and stop again, unplug move to spin to drain. Now it will do no agitation, no spin to drain just hums & clicks like the timer is moving but no action. The manual say "check fuse or reset circuit breaker." If it means my home’s circuit breaker there is no issue. How do I get to a "fuse" the manual I have shows nothing about how to even get the machine open. Do you have an online source to view, preferably for free? Any clue if I’m wasting my time on a 6 yr old washer or might this be an easy fix? Thanks for any input.
