Washer Repair
Washer Wont Go Into Spin Cycle And Wont Drain. I Replaced The Lid Control Switch That One Of Your Employees Suggested But Not Working Still
:slight_smile:
— Begin quote from titojun2002;783926
Washer Wont Go Into Spin Cycle And Wont Drain. I Replaced The Lid Control Switch That One Of Your Employees Suggested But Not Working Still. I’VE CHECKED THE BELT AND PULLEY AND THEY ARE STILL IN GOOD CONDITION. I DONT KNOW WHAT TO CKECK ANYMORE. PLEASE ADVISE
Hi.
Remove the front panel and using the multimeter check if the drain pump is getting 120VAC when timer set to drain.
If it is the 120VAC to the pump and it’s not turning - replace it [part]137108100[/part]
If the pump is running or trying to run check the drain hose from the tub to pump and pump itself for blockage.
Also is the motor turns on spin or makes a humming noise?
Simon.
wont do nothing. the machine remains quiet after the rinse cycle. timer indicator dont even move, so I dont know what is making it not to perdorm.
— Begin quote from titojun2002;783969
wont do nothing. the machine remains quiet after the rinse cycle. timer indicator dont even move, so I dont know what is making it not to perform.
Does the washer spins and drains during the wash cycle?
Simon.
the water dont drain anytime during any cycle:eek:
— Begin quote from Simon / APP Team;783933
Hi.
Simon.
If there is no voltage to the drain pump - most likely it’s a bad timer [part]131856400[/part]
Simon.
