Frigidaire Dryer Fails to Heat
I have a gas dryer that doesn’t produce any heat - everything else appears to be running properly. I’ve checked the sensor (measures about 12 ohms when disconnected to the system; the igniter measures about 60 ohms; and one of the solenoids (the 2-connector one at the rear) measures infinity. I suspect this is bad. The other solenoid with 3 connectors measures 1365, 1960, and 595 ohms taking all the combinations into account.
My question is how do the solenoids get removed from the assembly? Do you have to take the whole assembly out?
Thanks,
Mitch
Thanks Joe - appreciate the feedback. Never having done this kind of repair, it’s always reassuring to have someone experienced out there to allay my fears :wink:
