Frigidaire gas dryer
Could anyone tell or show me photo where the thermal fuse and ignitor located for Frigidaire gas dryer?
The coil with two terminals should have 1220 ± 50 Ohms.
The coil with three terminals, if held with terminals in upper position:
a). across the left and the middle terminals - 1365 ± 25 Ohms
b). across the right and the left terminals - 560 ± 25 Ohms.
I do not think there is something wrong with these parts. I would start with the gas valve coils unless you want to replace everything. Don’t make it more complicated than it is.
Hi Gene,
Your support was helpful, I found my secondary coil burn. I replaced the part and now my dryer is backed to normal operation. My wife is happy and thanks for your great job.
:stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue:
You’re welcome. I’m glad you were able to fix it and a happy wife is most important.
have a ge profile arctica the ice maker keeps melting then freezing back too produce a block of ice in bin also the temp in fridge has too bee changed (freze temp lowered 2 or 3 too 0 and fridge raised 32 too 37)
It could be a problem with the ice maker mold heater or with the temperature in the freezer. Turn the ice maker "off" and watch the temperature in the freezer for a couple days. Use a mercury thermometer. Post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=21491133&&model_id=219614
turned off ice maker the temp still fluctuate in both fridge and freezer have too adjust temp on pad on top of fridge every week
Watch the fan in the freezer for one or two days and post the results.
