frigidaire electric oven/broiler won't heat.
Hi there-
Everything else is working fine- the cooktop and the lights that indicate the oven is on/preheating. The inside is totally cold, though. It’s an electric oven from the frigidaire Classic Series, if that helps. Thank you so much!
Hi.
To assist you we need a complete model number.
Thank you.
So sorry about that! The model # is FEF366CCE - Thanks!
Hello.
The bake and broil functions in your oven both operates by the clock board.
If you feel OK to do the life test, then get to the clock (you will need a
voltmeter), and check first for 240v between L1 and L2.
Then check for 240v ,with "bake" on, BK to L2 out.
Same thing with "broil" on - BRL to L2 out.
If there s no 240v you have a bad clock.
The clock [part]AP3561834 [/part]
You will need an overlay [part]AP2126499 [/part]
If you have 240v at the test points, then trace the wires to
the elements and do the continuity tests.
Good luck. Post the results.
