Frigidaire Front loader no fast spin
My Frigidaire will not do the Fast Spin and the end of the wash cycle, it has been perfect for years. Can it be repaired or is it coming to the end of it’s life. I suspected the Motor, but I’m not sure, how can I check?
It could be a bad motor or a bad motor control board. Remove the bottom panel and look for an envelope with the tech sheets. Perform the tests as described there.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=356251&&model_id=116132
so what your are saying it is my pump going out not the bearing:cool:
are is it the tranmission
have i lost you and need to start over
