Frigidaire front loading washer, drum will not turn.
Frigidaire front loading washer. Drum will turn a few inches in either direction and then stops. I have already removed the drive belt and the motor turns freely. Where do I go from here?
Start with taking off the top and back and look for something obstructing the tub.
If you cannot find anything you will have to start removing the outer frame and tub. Here is the service manual which will help you do this.
http://frigidaireservicetips.com/pdfs/490_3cuftHorizontalAxisWasherSM.pdf
