Frigidaire Washer Doesn't Spin
My Frigidaire washer doesn’t spin. It agitates and drains. This seems to be the only problem. Could this be a solinoid (?spelling) problem? If so where is it located and how do I replace it? Thank you.
Background - Close to 10-years old & we live in house with tons of mineral deposits
DW started leaking (water coming out of top & sides). Gasket was replaced approx 6 mos ago so is in good shape. Tried treating with calcium/lime remover. DW very clean now but still leaks.
Thought leak maybe due to lack of drainage. Lots of clogs & residue build-up plus I can’t remove lower spray arm assembly.
any thoughts? will post more specifics in next post
My maytag washing machine Model Atlantis makes a loud noise when in the spin cycle only. What could it be, it almost sounds like a bad bearing. And how hard is it to fix.
Lift the washer from the front, remove the belt and check how freely the pump is moving in both directions. Post the result and the complete model number of the washer.
