hi,
we had a flood last wednesday in the basement and i think that my washer got wet. i tried to used it yesterday, the water is fine, draining is fine but its not moving or spinning at all!
can somebody pls help me!
tnx
Hi hope someone can help. I’ve replaced the timer and that didn’t work. The machine will not spin anymore than 3 times but I can see the belt moving.
gltf1040as
Just level the washer and they will drain properly.
My frigidaire front loading washer al of a suydden started to banging
loudly, like an uneven load does, but does it everytime no matter what size load, could you please tell me what that could be???
Thank You
Open the washer door and check if the inner tub is moving up & down and side to side. If it does, then the rear tub bearing has gone bad and probably the inner tub spider is bad as well. The bearing comes only as a part of the rear outer tub assembly.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5153300
