Frigidaire Washer Won't Stop Filling Up
Our washer recently stopped stopping. When I turn it on (no matter the load size, and even if it is empty) it will just fill up and fill up, and not stop. I can turn the dial to a spot where it will drain, and it drains just fine. But it won’t move forward in the cycle on its own.
What could be causing this, and is it worth fixing?
Open the control panel and check how good is the water pressure hose connected to the water level switch.
If the connection is good and the hose is not broken, replace the water level switch.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=116177
