Washer will not stop filling
My Frigidaire washer will not stop filling of water. I have replaced the switch Pressure for water level. but still the same thing.
Hi.
Turn the washer to fill and then unplug it. If the water still coming into the washer - replace the water inlet valve.
If it stops - check the air pressure hose for cracks and holes.
They call it Chamber 134369900
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5150136
Thank you. Post the results.
Simon.
— Begin quote from Chad993;747875
that hose does not leak air or water.
Hi.
If the water stop filling in when you unplug the washer check the wire harness from the pressure switch to control board, check all the connectors at control board.
If all checks fine - replace the control board.
Control board [part]137006000[/part]
Here are the breakdown diagrams and Replacement parts for Frigidaire FWFB9200ES0 Frigidaire/washer | AppliancePartsPros.com
Thank you.
Simon.
