washer wont stop filling
:eek: HELP.my washer won’t stop filling up and eventually overflows all over.
If you have to cut the water off to stop the water flow the water inlet valve is bad and needs replacing. If turning the washer off stops the water flow there is something wrong with the water level control such as the tube that runs from the water level control is stopped up or has came loose or the water level switch is bad. Hope this helps!
http://www.appliance-repair-it.com/clothes-washer-repair.html
