I had my washer diagnosed by a local appliance repairman and he said I had to replace the motor controller board. I replaced it and I am still having the same issue. The washer will cycle through each cycle but will not spin during the spin cycle. I checked the motor according to the schematic wiring diagram and Im getting the correct ohm readings with in tolerance. I checked the wiring leading from the motor controller board to the user main control panel face and it is good to include the wiring from the motor control board to the motor and it is good as well. What could be the issue? help:confused:
I found a fix to my problem with the frigidaire LTF700EG0. The door lock switch was bad. Symptoms where: the washer would aggitate throughout a wash cycle but would not spin during the wash cycle or on the spin cycle only. I initially replaced the motor controller card but it didnt fix the problem. I found my wiring schematic and diagram for the washer which led me to the user controller card or the door lock switch . I changed out the door lock switch because it was much cheaper than a controller card and it fixed the problem. Hope this helps someone.
