Frigidaire Front Loader Won't Spin
Bought in 2005 from Lowes.
The washer will go through the normal cycles, ( fill, agitate, tumble, drain, etc…) but won’t do the spin during the "Drain / Spin" portion of the sequence.
I have tried it with a load of clothes and empty - no change.
I also tried it with high and low speed spin settings - no change.
First thought it was the motor controller board, ( Electrolux p/n 134409900)so I replaced that - no luck.
Any ideas on the next step?
(I didn’t see an obvious "out of balance" switch on the schematics)
Thanks,
Tommy
Hello Tommyc95. Remove the door lock assembly from the unit and test the resistance of the PTC. If it is open or shorted, you will need to replace the door lock assembly. This will prevent the machine from spinning in the spin cycle. Hope this helps.
[part]AP4455026[/part]
Cabinet/top replacement parts for FRIGIDAIRE LTF2140ES0 Frigidaire/washer | AppliancePartsPros.com
Thanks Jeff. You hit the nail on the head!
I tested and got a little over 2kOhms - decided to replace it anyway.
The new door latch from APP was shipped and delivered as promised.
EASY install and now the washer works like new.
p.s. I also needed to replace a shock absorber. The tip in the instruction bulletin about using a 1/2" deep well socket to depress the locking tab on the mounting pin was worth the price of the part!
Thanks again for such great advice and service.
-Tommy
Great TommyC95! Glad you were able to fix it!! Thanks for doing businees with Appliancepartspros.com !:slight_smile: :slight_smile: :slight_smile:
Lately, I’ve found standing water and wet clothes in it after the cycle has finished. If I let the cycle run normally from the beginning, it fills normally and the timer dial moves normally. It agitates normally, then keeps on agitating through the rinse & spin cycles, and then stops (without eve spinning) once the dial get to the end of the cycle. If I turn the timer kno and position it back to the spin line and engage it again, it will spin and drain just fine from there.
- If I let a cycle run from the beginning, then stop it when the dial gets to rinse (by pressing in the timer knob and then pulling it back out), it will go into spin mode right away and drain properly.
- If I let a cycle run from the beginning, then stop it when the dial gets to rinse (by opening the lid and then closing it again), then it will go into spin mode right away and drain properly.
- No change in these symptoms in any of the cycles (regular, heavy,
delicate, etc) So, as long as I manually put it into a spin mode, it works fine. But if the cycle just runs normally, then it just keeps agitating and
never spins or drains.
NOTE: Lid switch already checked and is not the problem!
Since it will spin under some conditions this does not suggest a transmission issue but a timer issue. Try replacing it and see if that fixes things.
Hi:
I am having the same problem as the OP.
I’m not a repair person though, but I can get some one else to do it.
Is there any way I can easily test the door to rule it out before assuming that it is the pump?
Thanks,
CT
I am having the same problem but mine seems to be a bit different. The drain pump does not shut off and continues to run and there is no spin. Videos I have watched says the latch light does not come on if the door latch is defective. My door lock light comes on.
Is there a water level switch which tells the washer the drum is empty and to shut the pump off and spin or would the door latch switch cause this problem?
