I have a front load washer that the cycle finishes, but does not spin, even if I put it on "spin only" I opened the back up and there is no tech sheet. The belt is in good order. Given almost any part number, I feel I could fix it myself. Is there a way to get any error code from it? please help. thanks
Take off the front service panel and you should find a tech sheet inside.
I am getting an E47 error code on my LTF7000EG0 frigidaire washer. Does anyone have part number for this (door lock assembly)
thanks
It should be a 131763245.
