Front load washer is very loud and unbalanced on spin cycle.
Hello. i have a frigidaire front loader washer that just recently started making loud noises while on spin cycle and it shakes too hard. It also is not rinsing my clothes completely. Some clothes do get rinsed while others are still wet. any help is appreciated in finding out what the problem could be . thankyou.
Well, unfortunately sounds like you may have several problems.
I would take off the back and inspect the support mechanism for broken parts, as that is the likely cause of your vibration problem.
On the rinse side I suggest you clean out the pump and discharge area as something is likely impeding the flow of rinse water out of the machine.
Here is the parts diagrams for your machine from Frigidaire.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/5995446266.pdf
Good luck and let us know what you find.
