Front loading gibson gets stuck mid cycle
[SIZE=3]When set to ‘normal wash’, will run fine until about halfway done (about ¾ throughthe wash cycle).[/SIZE]
[SIZE=3]At this point the drum stops rotating and water continuouslytrickles in while machine “hums”. Seemsto be stuck at this point.[/SIZE]
[SIZE=3]When I change positions on the timer the machine fills,drains and spins normally at these positions.[/SIZE]
[SIZE=3]I changed the timer, but it still does the same thing. :eek: [/SIZE]
[SIZE=3]Any help would be appreciated.[/SIZE]
[SIZE=3]Thanks![/SIZE]
