Frost buildup
Recently had tremendous ice buildup in freezer section. Replaced, thermostat, temp. sensor and heater. Now all is well, except–
Have frost build up between exit of ice tray and entrance way in door ice dispenser shoot. What could be causing this?
Keep us posted!
Nat
You really pointed me in the right direction. The dispenser door part appears worn, so I ordered it. I also determined that the solenoid that controls the door was not activating. It was all rusted and dirty. I ordered it as well.
Thanks, I’ll let you know how it works out.
I have TBH18DAX, but no ice dispenser installed.
Recently, also have begun to get a great deal of frost accumulation in ice cube compartment and left top edge of freezer door.
As far as I know all other systems are go… it’s plenty cold. Only issue I’m
aware of is fridge compartment door gasket is broken out at the bottom.
Thx!
DL
DL - Make sure the freezer door is closing properly, make sure it’s level and the seal is making good contact all the way around. Also what is the temp inside the freezer?
Nat
I’m afraid I can find no listing for such a model number (and there should also be more to it). There are several models starting RH9[SIZE="4"]6[/SIZE]1… Can you double check it?
Most of that series featured a Frigidaire "Flair" range.
JFYI
Dan O.
http://www.appliance411.com/parts/?ref411=Hotpoint+Range*The Appliance Information Site*
=D~~~~~~
We were told by the dealer that this stove is too old for buy a regulator - has a gas leak - the serial # is FCE 2743660 and the manufacturers number is P1143006N-L - is there a regulator that can be used in its place.
Please email with an answer.
Thank you.
Looks like you can use the after market pressure regulator [part]AP4395536[/part]
as the replacement part.
