Gas Dryer, No heat
If the T-Stat, Hi Limit is bad alone, would that actually prevent the coils from working, and the ignitor from working ? If you have one bad fuse or sensor, would that shut it down ? Could the T-Stat HiLimit be crossed just to see if the gas comes on and the ignitor works ?
