Gas Range
Greetings
Originally, both the oven and the broiler failed to work.
I purchased and installed an Igniter Kit (WB2X9154).
Now the broiler works fine, but the oven still doesn’t work.
Advice?
Did you put new igniters on both the broil and bake burners?
— Begin quote from Jeff / APP Team;355152
Arrghh - I thought there was only one, and put in one at the broiler. I assume from your question that I missed one down low in the oven. Gordon Mulch
Yes here is the part number you need. Hope this helps.
[part]AP2014008[/part]
Gas control system replacement parts for General Electric JGSP10GEK3 Electric range | AppliancePartsPros.com
Excellent. Thanks for your help. -Gordon
