GE Double Oven Code F2 and clock failure
I have a GE JTP45W0(or o)A1WW double electric wall mount oven. The upper oven gives code F2 shortly after beginning the self clean process. (the lower oven works fine). From what i can tell, this may be the temp. sensor? I attempted to remove, with the two screws inside the oven, but it seems that you have to access the back to unplug this part? Any advice? Also, i cannot seem to find this particular model anywhere, which model does it cross reference with?
Second problem, the clock randomly changes time. I set the clock, and it just randomly will change to various times. Everything else seems to work fine. Any suggestions for this?
