I have a GE wall oven, runs up to temp & has intermittent F3 errors, sometines F4 and F5. Usually can be cleared , but its a pain t shut it off & restart over & over.
I checked the temp probe - 1.083 K-ohms, so that looks right. I don’t see this model number on this website to get part numbers for the control panel…
Need help with the part numbers, or any other ideas…
Hi,
Are you sure your model number is correct?
Could it be model number: JTP27WW1WW
Yup that is the correct number from the double oven.
I actually bought a replacement control panel, but I am at a standstill now since the connector patterns aren’t the same, and no instructions were included.
The only help I got was ""Wiring may be different from the original and may require a technician to install""
