Ge Dryer Has No Heat
I HAVE A GE GAS DRYER THAT DOE NOT HAVE HEAT . IT DOES CYCLE BUT WHEN ITS DONE THE CLOTHES ARE STILL PRETTY WET!! I LIVE IN HOUSE WITH 10 PEOPEL AND THIS IS THE ONLY DRYER AND WEVEBEEN TAKIN THE CLOTHES TOTHE LAUNDRY MAT I NEED A FIX QICK . NOW I NEED TO KNOW HOW TO GET TO THE HEATER I GUESS TO LOOK AT IT I WOULD LIKE SOMEONE TO TELL ME WHAT TO DO IN THIS CASE HOW TO GET O THE HEATER
— Begin quote from BIZNVICTORIA;51299
…WHEN ITS DONE THE CLOTHES ARE STILL PRETTY WET!!..
Are they warm or cold at that time?
The model number you posted does not come up. Is it American model?
I have a Maytag Washer and it only works in the "Delicate" cycle. It will fill with water in other cycles but that’s all, it works fine in the Delicate cycle. I think it’s the time but would appreciate another opinion.
Does it make any noise?
If it does not then the problem most likely is a bad timer.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26499
— Begin quote from Gene;134230
  • The timer [part]AP4026633[/part]
Here are the breakdown diagrams and Replacement parts for MAYTAG LAT9604AAE | AppliancePartsPros.com
Thanks Gene, There is no noise, I think we are going with a new machine since the old one is 15 years old.
You probably right. Good luck with a new one.
how do i go about replacing the front bearing on this hot point dryer? is there any tricks to make it easy?
                                             Thank You,
                                              [email]scott58@netzero.com[/email]
